bigfootford
Feb 09, 2017Nomad III
GULFMAN wrote:
bigfootford,
Is your water pump located under the table floor by the table leg?
If so did tank fit down in there beside the pump?
Did you keep the original pump?
Not for sure what pump i have but will look.
Thanks all for the reply's
My BF is a 2500 9'6".
My pump is in the compartment under the rear dinette seat wall that is against the bathroom and is . covered by 1/8 plywood.
In the compartment is the hot water tank too, along with it's plumbing and the winterizing plumbing.
I installed the Accumulator Tank on it's side... in that compartment against the hot water tank.
Prior to the accumulator tank install I replaced the OEM water pump because it was so noisy. I installed the Surflo Whisper pump... hahahaaa It was almost as noisy as the OEM... Plumbing tubing actually makes all the noise.
So I liked how Reddog1's Accumulator tank worked along with other local Rv.net folks so I installed the tank...
I can run about 1.5 quarts before the pump turns on...
Sorry, I have no pictures.
Jim
