77rollalong wrote:
I had a problem with our tank that there was a screen in the outlet of the tank that was plugged, i pinched that out, put in a shutoff valve and placed a screen filter after to the pump. the pump should almost gravity feed from the tank, so it should not take much to remove the air between the tank and the pump, unless the pump has gone bad.. have you tried putting a hose on the suction side of the pump into a gallon of water and see if it will suck...
The snake didn’t work. It felt like it hit something solid which woudn’t budge. I’ll try the air compressor next.
