ripperoo
Jul 16, 2013Explorer
sskwise wrote:
Ripperoo, I noticed that my awning is sagging a little also. Can you discribe what you are talking about as a center support?
SSKWISE, I got one of these: Tension Rafter
When the awning is stowed, I put a little positive up lift on it, just slightly higher than the end supports. Helps keep the center from sagging down, permanently bending it. With a slight up curven in the middle, water doesn't tend to accumulate in the middle; seems to run out the ends. Also, it's nice to use as a center rafter when the awning is out. Helps keep water from puddling in the center, and again keeps the roller from bending inward toward the camper when tensioned.
44,059 PostsLatest Activity: Mar 18, 2026
