Hitch_Pin
Jul 30, 2014Explorer
Water Shut Off ?
Does anyone shut off they're water before going to bed? If so, do you go outside to shut it off or did you install a valve inside. Thinks!
whiteeye42 wrote:GaryWT wrote:
I never shut it off and dont use a regulator. Probably a good idea to shut it off when we leave for the day but never think of it. We never use the pump or have water in our tank so shutting off at night would not work.
ya and you are just looking to have troubles with the water lines in the trailer by not using a regulator the lines in the trailer are only rated to with stand 45-50 psi it would only take it one time to have the pressure spike to 65 psi or more while you are gone from the trailer only to come back to a real mess ask me how i know but it is your trailer so you do as you think fit
