scbwr
Aug 29, 2016Explorer II
Were you using water from your tank or were you hooked up to water at the campground? If the water was from the campground hook up or if you filled the tank from a different source than normal, than the smell could be from the water. If the water has a lot of sulphur in it, which can easily happen with well water, the hot water will stink. When that happens, just drain all the water out when you leave or get home and then flush with water from a good source.
44,056 PostsLatest Activity: Jan 12, 2020
