opnspaces
Mar 16, 2020Navigator III
I've never had to winterize my trailer, but the steps to dewinterize should be fairly straightforward and the same as flushing after sanitizing.
Before adding any water look in the owners manual and also crawl around in and out of the trailer to find.
Turn water pump off.
Leave water heater bypassed.
Open the fresh water tank drain and let it drain out. If clear water comes out you're good. If pink comes out you have antifreeze in the tank and need to fill and drain repeatedly until it runs clear.
Put water in the fresh tank but leave the pump turned off at the switch.
Open both the hot and cold knobs on a faucet in the trailer.
Open the low point drains.
Open the water heater drain.
With the drains open turn on the water pump and let it run for about 30 seconds then turn the pump off at the switch. You can do the rest of the flush using city water instead of waiting on the pump.
Now close all drains except the water heater drain and turn off the faucet.
Attach city water hose to trailer and turn it on. You should have at least a cheap water pressure reducer from Walmart before attaching the hose.
If you have an outside shower open both valves on that shower. If no outside shower then open a sink faucet.
Wait for the outside shower to stop spurting air and run clear then close the valve. There should be no water pouring out of the water heater drain.
Now open each faucet in the trailer and wait until they run clear. Do not forget the shower or to flush the toilet.
Turn off all faucets and find the water heater bypass valves and turn them to take the heater out of bypass. Water should start coming out of the drain plug.
Wait until water runs clear and then shut off the hose.
Replace the drain plug in the water heater and again turn on the hot water faucet on the outside shower. This is to bleed the air out of the water heater while the tank is filling.
Turn on city water and wait until the water heater fills and the outside shower stops spurting air. Then turn off the shower.
Check in and out of cabinets and try to visually follow the water lines throughout the trailer. You are looking for any water seepage or leaks.
Your system should be ready to use.
- Fresh water fill port.
- City water fill port.
- Low point drain(s).
- Fresh water tank drain.
- Water heater drain.
- Water heater bypass valves.
44,066 PostsLatest Activity: Apr 15, 2026
