inthedarkExplorerMay 15, 2013water tank replacementI have just got a 2003 arctic fox that has a hole in the top of the fresh water tank. any idea what it takes to replace it? does not look like its going to be easy to get at.
inthedarkExplorerMay 16, 2013Thank you all. turns out its a pretty easy fix. factory is friendly and helpful.
Related ContentWater Heater Replacement RecommendationsWater tank won't fillFresh Water Tank ReplacementGrey water tank won't drain completelyNo flow from hot water tank Nautilus P1 system
