Dome's avatar
Dome
water tank
posting for a friend, he wants to know where the water tank is on his i-go lite trailer is? He thinks it's under the sink but there is no why to access it unless he take a panel out. Is this correct?
  • Dome wrote:
    he fills the tank through a port that is under the kitchen window. I was thinking the tank would be there but I don't that area has enough space for a 35/40 gallon tank. I'm thinking the tank is in the back half of the trailer there is a hot and cold water drain back there. I guessing there is no access to the tank sense it is between the frame rails. thanks for the information.
    Access to tank then would be from underneath. If enclosed underbelly then have to remove section for access.
    Standing in front of kitchen window....probably standing right over tank
  • he fills the tank through a port that is under the kitchen window. I was thinking the tank would be there but I don't think that area has enough space for a 35/40 gallon tank. I'm thinking the tank is in the back half of the trailer there is a hot and cold water drain back there. I guessing there is no access to the tank sense it is between the frame rails. thanks for the information.
  • Under bed
    Under sofa
    Under bench seat
    Under....where they can fit it.
    Where does your friend fill his tank...it's opposite/below the fill port
  • In the absence of verifiable information, above the axle(s) would make sense since that's the tank most likely to be full when traveling and it would keep the extra weight neutral.
  • Look under the trailer for a drain spigot. The tank will be above it.
  • Look under the bed. That is a common place for fresh water tank.
