Mastiff_mama's avatar
Mastiff_mama
Water troubles :(
Hello everyone. I need your help. The other day I decided to flush the waterline in our trailer as the water tasted and smelled off. Not sure if it was the hose or the water lines I filled the water tank with water and some bleach. Then put a mixture of water and beach in the hose that is used to hook us to our water supply. I turned on the water pump for a while to flush the water lines and then hooked the hose back up and ran clean water through to get rid of the bleach. Now I have two problems. The water running from the kitchen tap barley comes out and now my out door shower won't work. What could I have done running the water from the fresh water holding tank that would have messed up the kitchen water and the shower. Please help me figure this out. Thank you
Natalie
