opnspaces
Mar 06, 2023Navigator III
ncladfw3 wrote:
Ok thanks, when I unscrewed the aerator that improved the flow. I still don't have hot water though. It is supposed to be an electric HW heater. I checked all of the circuit breakers and they are fine. Outside water valve under the trailer is closed.
You should be able to carefully pull the aerator apart and clean out whatever is clogging it and it should work better when you screw it back in.
