Terryallan
May 14, 2016Explorer II
I can see using air bags to ease the ride. However. If using them to level / raise the rear of the TT. You would be changing the amount of weight the WDH is transferring. You would remove the tension on the weight bars.
In truth. IF you have the WDH setup correctly. The TV will sit very close to level. There will be very little sag, and no headlights huntin Coons, or pointing to the sky. A little air after that to cushion the ride wouldn't hurt, but not enough to raise the rear.
Remember. Air bags can level the TV, But will not transfer any lost weight to the steering axle. IMOP if you get your hitch correct. You would not need air bags.
