ChooChooMan74
Jul 05, 2016Explorer
myredracer wrote:
You need a min. of 5 links under tension so that the hanger brackets or spring bars won't hit the A-frame. If you have over-slung axles (axles above springs), the A-frame will be closer to the ground and you will need fewer links under tension, but not less than 5. One set of Reese instructions for the round bar version says: "If there are less than 5 links between hook and u-bolt adjust ballmount angle rearward, and repeat procedure - see Fig. 3 & 4 below" Reese's instructions are not the greatest and they have different ones for '09 and earlier and '10 and later.
The best thing you can do is go to the towing forum and there is a sticky at the very top that goes into a lot of detail and discussion on the Reese DC hitches.
Thank you, but the instructions for the dual cam round bar is different than the instructions for the round bar WITHOUT the dual cam, where the chains connect to the bars instead of the cams. With the cams, it doesn't state any number of links, as 5 links PLUS the cam brackets is more like 7 or 8 links for a non dual cam setup.
44,066 PostsLatest Activity: May 16, 2026
