phenrichs
Jul 07, 2016Explorer
I have read this entire thread. I will summarize so far as there are multiple replies with correct information.
Your 3 link setup gives you the correct numbers on the scale but from the pics and other information is not adjusted properly for angle as bars are too high (close to A frame) and trailer appears nose high. You can continue if you are comfortable. If you want to get picky the recommendation is to readjust starting with the hitch head to get the bars set parallel to the frame under tension. This means it most likely will not be 3 links anymore but you will adjust to get back to the same weight numbers or as close as you can.
44,066 PostsLatest Activity: May 16, 2026
