sncraig
Jul 19, 2015Explorer
WD hitch or not
I am looking into buying a new TT and can't decide if I need a WD hitch. We have had two 35'+ 5th wheels over the past few years and pull with 2011 F250 diesel with rear air bags I added. So my questi...
ScottG wrote:MM49 wrote:
You probably don't need a WD hitch. I'm pulling a 30' TT with 1204lb TW. I also have electronic sway control. You should have few problems with the rear suspension. Give it a try.
MM49
You should know that your "electronic sway control" does nothing while your driving down the road unless you have a sway situation that is so bad that the computer thinks your going to crash. And then the only action it takes is to fully stop the truck - not make minor adjustments to maintain control. It's not an active system that replaces a WDH (though the way it's marketed certainly leads one to assume so).
BTW, you would be shocked how much nicer towing is with a WDH.
