Tequila wrote:
Thi sis all a bit confuisuibgn to me. I have a 1 ton duaklly with superspings and a Torklift superhitch. I am picking up a trailer with an unloaded hitch weight of 550 lbs. I am thinking pof towing it without the equalizer bars for a day or 2 to test it out. I do not think I will need them, but I am wondering if putting them on with even minor tension will help sway. Curently the rear of the truck is about 3 inches higher than the front unloaded.
You'll not need weight distibution but you will need the anti-sway capabilities of the hitch. If you are convinced to take a test drive without the Equalizer, I suggest you make sure to go on the highway with some winds and ensure you experience 18-wheelers going both ways at highway speeds. I stongly suggest at all times having tongue weight be at least 10% of total trailer weight.
You have plenty truck for payload and towing capacity but sway is a resonance condition affecting directional stability of the trailer. The anti-sway device drops the resonance frequency (and amplitude) of the rig due to the articulating joint so that it is unlikely to be encountered during normal towing speeds.
