campigloo wrote:
If you decide you need a WD you can get a very basic EazLift for about 250.00. It will do just fine, not the latest and greatest but capable. You can add sway contro later for less that 100.00 if you want to. EazLift has come out with one with built in sway control for 460.00 if you want to go that way. Both prices are through Amazon.
Henri,
You sound like a practical guy. I agree with Mike (campigloo) above. There really isn't a compelling reason to buy some of the more expensive hitches. A simple 1000# WD will help keep the front axle from steering light. Offhand, I do also own an expensive Hensley hitch (for a past very undersized truck) but I still prefer to use a common Eaz-Lift with my larger trucks because it is quicker to hitch. The lower price Eaz-Lift (including a "free" detachable friction sway control) looks like this:
The more expensive Eaz-lift looks like this:
The advantages to the pricy one are mainly that the straight bars assemble into clean, dry holes. So when you store them, they aren't greasy like the lower-cost bent bar set. I have the bent bar, and I throw sandwich bags over the greasy hook ends when I store them. The minor inconvenience saves $200 up front. But there is one other advantage to the straight bars, and that is that the hitch bars clear driveway dips better.
Price-wise, I often like to buy from PPL and their service has been fine too. Here is a link to their Eaz-Lift page:
http://www.pplmotorhomes.com/parts/eaz-lift-rv-hitches-tow-bars-dollys.htmAmazon may be cheaper with free shipping. At any rate, the bent-bar hitches are closer to $200 than $250.
Since the included "friction-sway-control" pak was cheaper "with" than the "without inclusion" pak, I bought the former version. It is the same thing except the inclusion pak includes the components to an adjustable sliding bar assembly that uses a brake pad to damp sway (turning) with pure friction. I don't bother to use the sway control. You may wonder about a miracle "upgrade" claim to the straight-bar automatic sway control, such as
promoted here. The miracle physics are that this hitch assembly has very ordinary built-in friction in it's swivel joints and bar sliders, not so hi-tech afterall. At least this brand version is also adjustable... a similar popular brand isn't.
If you have a concern with Eaz-Lift,
here is a short video that explains how WD was invented by this company. At one time, Eaz-Lift also used to supply all the tempered steel WD bars for all the competing more expensive brands. They all work, but pretty much to the same degree except for a few. Lotta hype out there, eyeballing our wallets.
Also noticed you mentioned using a K&N filter. One caveat: If you will ever be in dusty conditions, they tend to pass a lot of fine dirt until they finally start to plug. Highway isn't so bad, but we found we couldn't use them on off-road vehicles without excessive engine wear, and neither could most other folks. For reclean-ability and water resistance off-road, we usually used oiled foam or fur-foam. But the best free-breathing small particle filters were still OEM paper types, if they don't have to be replaced too often. I personally think K&N is another case of advertising hype, fine on a clean dragstrip, boat etc.
Wes
