hohenwald48
Sep 05, 2016Explorer
WDH - Just Wonderin'
I was thinking about how a WDH works and had a thought. When you tighten up the spring bars you are actually lifting the rear of the TV and transferring weight from the TV rear wheels to the TV front axle and to the TT axles.
Could you misadjust the spring bars to the point where you remove so much weight from the rear axle as to actually cause sway? I mean if you really, really misadjusted the bars and they were strong enough I guess you could actually lift the TV rear wheels off the ground.
Just thinking. Probably won't try it. :)
