schlep1967
Apr 05, 2022Nomad
AdirondackerSouth wrote:schlep1967 wrote:
First we need to clear some things up. Your title says WDH and your question is about anti-sway.
Depending on what the trailer weighs and what you are pulling it with, you may not need a WDH. I'm pretty sure that is a fairly light trailer. If you are pulling it with a 1500 series truck, you probably don't need the WDH.
As for the anti-sway, there are friction bars you can add that would do the job for that trailer.
The terminology is confusing to me. Friction bars are ones that attach to the trailers tongue with bolts and a small socket and are connected to the hitch with a small ball that is offset from the main towing ball.
Is that correct?
Yes that is correct.
