work2much wrote:
...All of this, plus emissions, and lower rear end gear means I should expect less fuel economy. I haven't hand calced a tank yet but going by the notoriously inaccurate dash readout it looks like about 12mpg with the TC on which would be about 3 mpg less than the 04.
I am disappointed in my MPG on my '04. I have only had the opportunity to hand calculate it a couple of times. It appears 10 to 11 MPG is it. It has 4:11 gears, but typically run it between 1800 and 2000 RPM. My '96 was 12.5 with the same TC.
With the in-depth description you gave, I can see the big difference in weight. It sure is not obvious just looking at the truck. Now I'm thinking the drama with the licensing is due to the GVWR.
