Lynnmor
Mar 02, 2020Explorer II
Matt1221 wrote:
No I don't know yet, because I don't have physical possession of said trailer. Just the lady that did the walk thru- was going over all the switches & got to where the electric hot water heater switch should be (by the awning & water pump & tank meters), then got confused in a hurry & said it was gas only.I said What? she said but the outside is. When she opened the hot water cover I didn't see a spot where the element would be, so I can only assume it is gas at this point. But if it is like someone else mentioned I am going to put the kit in it.
The kit will give you only about 30% of the heat that you would get with a standard heating element. You also should know that the anode rod will be eliminated and the warranty will be void.
