Oregun's avatar
Oregun
Nomad
Sep 10, 2015
Weighed my rig
Greetings all.
Here is a picture of my rig courtesy of google on I84 in the Columbia Gorge.
I have a 99 F350 2WD with V10 engine. The tires are almost 6 years
old. Currently Hankook 265/75/16E which have been good tires.
I don't put a lot of miles on the tires as I just use the truck for camping, hauling firewood and other hauling around town. I put about 3k miles per year tops. But its time to think about replacing them.
Recently weighed my rig on a camping trip and got
Front 3800
Rear 6500
Total 10300
GVWR on my truck is 9900
Front GAWR 4400
Rear GAWR 6830
When I take my daughter and her stuff camping with me the rear weight goes up right to the max. (6800)
How safe is my vehicle? Note: I carried the same camper on my 1990 F250HD for 15 years without mishap.
Looking for options on new tires to increase the safety margin.
I see that 285/75r16 tires can go up to 3750 lbs but I can't find out what my current rims can handle.
I am willing to go to 19.5/vision tires/wheels but what about brake upgrades and spare tire?
Suggestions anyone? Thanks for your inputs.
  • Oregun wrote:
    Kayteg1 wrote:
    Axle can take some extra load, but what is your tires rating?
    Current tires are rated at 3415 at 80psi
    I would def upgrade the tires. Looks like the wheels are OK.
  • I don't see a problem with the current tires rating IF you are taking care and not driving like a speed demon down the road. Just stick with a quality tire.
    After all, they have been serving you well and did so on the previous truck too.
  • Axle can take some extra load, but what is your tires rating?
    I remember having 7300lb on F250 rear taking some gravel, but I bought Discoverer's tires that had the highest ratings in the size.
    I had Hancock in 19.5" size on my F450 and after over 80k they still had good tread, but hauling heavy had a blow out, so eventually had to replace the rest of them even with good tread. I remember they were close to 10 years.
    6 years is not much for truck tires if they are keep in shade, but check them for cracks and if in doubt, take them to reputable shop for inspection.
  • Edit; I see you're already running a 1 ton. Are they steelies?
    Forged Aluminum wheels , see link in original post.
  • Oregun wrote:
    Greetings all.
    Front 3800
    Rear 6500
    Total 10300
    Front GAWR 4400
    Rear GAWR 6830
    Get some OE steelies from a 1 ton and the 285 rated at 3750 you'll be all set. That's what we did and have been running Nitto DG for 2 seasons now. Very pleased.
    Good luck, Bill
