- drsteveExplorerI once tried hauling a 250 lb dirt bike on the bumper of a 23' TT. Caused a sway event that nearly put me in the median. Never again.
- TomG2ExplorerA couple of the guesses are not too far off, but they totally disregard the dynamics of the situation. What happens when things move, bounce and flex as the trailer is towed down the rough highway? Much more complex and beyond the scope of an Internet opinion game.
"Statics is (physics) the branch of mechanics concerned with forces in static equilibrium while dynamics is (mechanics) the branch of mechanics that is concerned with the effects of forces on the motion of objects." - GrandpaKipExplorer II
schlep1967 wrote:
GrandpaKip wrote:
Real world measurement.
I added a cargo rack to the frame of my camper. It weighs 55 pounds. I put 100 pounds on the rack.
All this was done as the tongue sat on a scale with the trailer level.
The weight went down 24 pounds.
So, the tongue weight decreased by about 15.5%.
Let me finish your sentence. So, the tongue weight decreased by about 15.5% of the weight added to the rear of the trailer.
What was the tongue weight (scale reading) before? The 24 pounds divided by that number would be the amount the tongue weight decreased.
You are correct. Thanks for the clarification.
The tongue weight was decreased by 4.1%...24/585
For the OP’s query, he could figure that about 15% of the weight added aft would be removed from the tongue weight. If he added 500# to the rear, it would remove about 75#. To know what the effect would be, he would have to know the trailer and tongue weights.
Of course, this assumes (yeah, I know) that the frame can handle it. - TomG2Explorer
valhalla360 wrote:
....snip.....
So far no point has been made.
A lot of darts have been thrown but not many points made. - valhalla360Navigator
JIMNLIN wrote:
LOL..those dimensions won't do any good simply because A 38' triaxle has no center point as in a teeter totter. From the farthest fore and aft spring hangers can be 8-9' apart.
I've made my point to the OP .... I'm done.
Give me the numbers and I'll run the calculations.
Assuming even spacing, the center of the 3 axles is the center point of the axle group.
So far no point has been made. - JIMNLINExplorer IIILOL..those dimensions won't do any good simply because A 38' triaxle has no center point as in a teeter totter. From the farthest fore and aft spring hangers can be 8-9' apart.
I've made my point to the OP .... I'm done. - Jebby14Explorertongue weight isnt the issue (it can be added back and it will likely only be 50-75 lb reduction anyway). the issue is how is he holding it there? the frame is going to take a pounding as is the bike. put it in the bed.
JIMNLIN wrote:
Gooseneck & 5th Wheel trailers have a different geometry from bumper pulls as they are shooting for 20-50% of the weight on the hitch
Looks like your experience with owning and pulling rv and working non rv trailers has been different than mine. Before making claims about my trailers suspensions you need to do some home work prior on what trailers I have and see the different suspension setups out here on non rv trailers. Their not all the same.
My 38' GN triaxle stock trailer and other flatdecks suspensions are set up no different than big 5th wheel/toy haulers for 15-25 percent hitch weights. Even my 18' and 22' bumper pull car haulers suspensions are set up as a TT with 10-15 percent hitch weight. I bought them this way so they can be pulled with a heavy duty 3/4 ton truck.
Your point of non rv trailer suspension set ups has been made before but in the real world not all are as you claim. Sure we have various types of non rv trailers that their suspensions are set farther aft which....but not all are as such.
That 200+ lb was a measured weight number on the hitch from the 2200 lb bull. All my trailers are pulled level.
A teeter totter principle of a center balance point is a poor example of how suspension work on trailers especially with multi axles. Point is adding 300 lbs on the back of the tandem axle trailers rear bumper won't make the hitch weight lessor the same amount.
The actual suspension system doesn't make much difference unless you get wildly out of level in terms of calculating the hitch weight. If it's running level and there is nothing wrong with the suspension, the weight should be pretty close to evenly distributed between the axles and the teeter totter analogy still applies.
Give us the dimensions on your cattle trailer including the position of the bull. I'll give you 1000-1 odds, the calculations make it quite obvious why you saw only 200lb come off the hitch with no consideration of the suspension type only the spacing between the center line of the axles and the hitch/bull. GrandpaKip wrote:
What was the tongue weight (scale reading) before? The 24 pounds divided by that number would be the amount the tongue weight decreased.- GrandpaKipExplorer IIReal world measurement.
