Francesca Knowles wrote:
Thing is, I keep looking at pictures, and it appears to me that the bars/chains must be pulling on the trailer tongue at the connection point, pushing it down against the fulcrum provided by the ball. I s'pose that's wrong, but it's the only logic my simple mind can come up with that explains why the front end of the tug gets "lighter".
Francesca, the following is not a reply to your diagram with the red and blue arrows. I didn't see that until after I posted the following.
With
no weight distribution applied:
1) the ball coupler pushes downward on the ball,
2) the TV's rear axle serves as a fulcrum, and
3) the TV's front axle gets "lighter" (load is removed).
If the distance from the rear axle to the ball is equal to one-half the distance from the rear axle to the front axle, the load removed from the front axle will be equal to one-half of the tongue weight.
With weight distribution applied, each lift chain might be tensioned to 1000#, giving a total tension of 2000# for two chains. This means a downward force of 2000# is applied to the TT's A-frame about 30" behind the ball coupler.
With the ball coupler acting as a fulcrum, and assuming the distance from coupler to TT's axles is 240", the 2000# downward force acting 30" behind the ball would be countered by an added force of 2000#*30"/240" = 250# acting upward against the TT's tires.
Now, the TV's rear axle becomes a fulcrum, and the added force acting upward against the TT's tires causes an added upward force to act against the TV's front tires
If the distance from the TV's rear axle to TT's axles is twice the distance form the TV's rear axle to front axle, the amount of load added to the front tires will be equal to twice the load added to the TT's tires.
In other words:
4) the tension in the WD bar lift chains exerts a downward force on the A-frame,
5) the downward force on the A-frame (with ball acting as fulcrum) causes an upward force on the TT's tires (load is added),
6) the upward force on the TT's tires (with TV's rear axle acting as fulcrum) causes an upward force on the TV's front tires (load is added), and
7) the upward force on the TT's tires (with TV's front axle acting as fulcrum) causes load to be removed from the TV's rear tires.
The load removed from the rear tires, via application of WD, will be equal to the sum of the loads added to the front tires and TT's tires.
Ron
