rbpru wrote:
If I understand the numbers correctly, a WD hitch transfers about 25% of the ball weight back onto the TT axels and divides the remaining 75% more evenly between the front and rear axles of the TV.
Does this mean with 500 lbs. of tongue weight, I gain 125 lbs. more cargo capacity on the TV? And lose 125 lbs. of TT cargo capacity?
When you drop the coupler on the ball without using WD,
a load equal to about 40-50% of the tongue weight will be removed from the front axle, and
a load equal to about 140-150% of TW will be added to the rear axle.
The combined added load on the TV's front and rear axles will be equal to 100% of the tongue weight.
If you then adjust the WDH to restore all of the load removed from the TV's front axle,
a load equal to about 20-25% of TW will be transferred to the TT's axles.
A load equal to about 40-50% of TW will be added to the TV's front axle, and
a load equal to about 60-75% of TW will be removed from the TV's rear axle.
The net load change on the front axle due to TW and WD will be zero, and
the net load change on the rear axle will be an addition equal to about 75-80% of TW.
The net load change on the TV's axles will be an addition equal to about 75-80% of TW.
So, you are correct -- with a TW of 500#,
when the WDH is adjusted to transfer a load equal to 20-25% of TW to the TT's axles,
the load on the TT's axles will increase by about 100-125#, and
the load on the TV's axles will decrease by about 100-125#.
In compliance with the law of conservation of mass,
mass has been neither created nor destroyed by the WD process.
Ron
