DR1VENbyCAMPING
Oct 09, 2017Explorer
SoundGuy wrote:DR1VENbyCAMPING wrote:
I just bought a Passport 153ML....my 2013 Honda ridgeline states "We don't recommend using a weight distribution hitch"
Forum member ***Link Removed*** tows a Coachmen Freedom Express 192RBS with his Ridgeline and has much experience with this combination ... I'd suggest you PM him for his thoughts on the matter.
Thank you SoundGuy...VERY much...I will.
And others...Thank you for the input as well.
I went back and noticed the fresh tank is under the front of the coach.....Black and grey are behind the axel.
I'm putting 2 6v batteries on it, it has dual propane tanks, and with the front storage I'm getting concerned a bit to not do bars...additional research and comments here(Thank you again) have assured me as long as installed properly does not void truck warranty so its allowed.
Going with 800lb equalizer hitch and friction sway...I'm going to be averaging 550+ from the looks of things now especially with the front pass-thru as the main storage...If water tank is even only half filled(Will of course try to travel without), That alone is 160 additional.....At least its equipped with a class III receiver standard...
