ticki2
Jan 13, 2016Explorer
crossent wrote:
It's rated at 400-4000 or 600-6000 WD.
A WD hitch is going to move some of the weight off the rear axle and move it to the front axle . It will also transfer some of the rear axle weight to the trailer axles . It may not level the truck depending on the load but it should level the trailer if set up properly . I would find a new dealer . Clearly the hitch is rated higher with a WD hitch than without .
