Reality_Check
Jan 16, 2016Nomad II
It started with this:
Opps and irrelevant of course.
But, you kept going:
Thanks for clearing everything up... But once again, you have no idea.
As has been pointed out to you (well done jimh425), the discussion turned to the 'rear overhang' issue (which you brought up). Feel free to take a tape measure anywhere you want...to verify what is common knowledge.
It appears that there is confusion at your end now about what the discussion was about...cab to axle or rear overhang. You showed pictures of short boxes and long boxes and duals...and then had the obvious pointed out to you. But there is still confusion????
I'm sure others can sympathize with my affliction over your writings. Seemingly all knowing on all subjects. It's wearing. But, according to you, I have limited experience, so what do I know.
Carry on...
Kayteg1 wrote:
They are both long beds.
Kayteg1 wrote:
You make broad statement on your limited experience.
Kayteg1 wrote:
You are right that Ford lists all rear overhangs at 52", what leaves about 50" for cab to axle, but F550 are also coming with about 80" cab to axle.
The white truck seem to have the 50/50 box, but I keep measuring the front of the box to rear overhang of new DUALLY trucks and no matter what picture I take, it is coming like 64/36.
Would probably take a visit to a dealer with tape measure ....
jimh425 wrote:
... Obviously, if the overhang is the same for both SWB and LWB, the extra distance is at the front of the bed for the LWB.
Carry on...
