Wishin
Nov 13, 2013Explorer
It sounds like you really don't need the air bags for the travel trailer. If true,then just put 10 psi in the bags before you adjust your hitch and leave the pressure at 10 psi. If you feel you want to add air later, you'll then need to re-adjust the hitch to make sure you're putting enough weight back on the front axle. Pumping up the air bags after the hitch is adjusted will reduce the effectiveness of the w/d hitch which is why you need to re-adjust the w/d hitch if you change the air pressure.
44,056 PostsLatest Activity: May 04, 2014
