nohurry
Apr 15, 2015Explorer
You may not need as much tension, but it's still a good idea to return the weight to the front axle. Before hooking up, measure the distance from the ground to the front fender lip, then hook up the WD bars and tighten till the measurement is around 1" higher or about the same, but never lower. Hope that helps.
