downtheroad wrote:
I think you can back up with any basic weight distribution hitch.
It's the anti-sway component that may (may) cause problems when backing up, especially in a tight angle...
Usually friction bar anti sway devices recommend removal when backing.
I believe this is correct. I've used WD but never used sway control. I didn't have any trouble with backing into tight places.
With the newer F250/F350 diesel, you can have an 850 lb weight carrying hitch capacity without WD. I have a 650 lb weight carrying capacity hitch on my 5.4L F250. Don't know what GM and Ram offer. I prefer to not have to use WD and sway control if I don't have to.
