911golf
Jan 27, 2015Explorer
Been using the Andersen for the past two seasons. Like it so far. Does what it is suppose to very well. Quiet too. very light weight as well if you have to consider hitch weight or payload. Only constructive feedback I have is the triangle plate should be as straight as possible when hooking up.....meaning when you park your TT, your vehicle should be in alignment with the TT. You can still be at an angle when you disconnect or connect, but then you will need to straighten up the triangle plate before you distribute the weight. The Andersen site has a video under FAQ for this. Now, I have found it very rare where my vehicle is not in alignment backing in the TT. So far it is proven worthy. I have seen more and more of them being used.
44,052 PostsLatest Activity: Oct 25, 2025
