My_Roadtrek
Jan 27, 2015Explorer
Blue Ox sway pro. Watch the video.
Blue Ox Instalation
Evenly distributes weight over axles of tow vehicle and trailer for stability and control
Creates a level ride for both tow vehicle and trailer
Built-in sway control helps to prevent trailer sway
Constant tension in trunnions helps force trailer in line
Rotating lift brackets ensure that chains are tight and secure to keep spring bars from moving
Trunnion spring bars flex for a controlled, even ride
Automatically lock in place and easily remove
No pins or clips needed - self-locking devices function throughout system
Easy-to-operate bracket locks automatically secure rotating brackets in place and release with push of lock pin
2 Grease zerks inside head assembly make maintenance simple and clean
Unique, rotating-latch lift brackets connect spring bars to trailer
Quick and simple to use - insert lift chain into slot and rotate bracket with wrench
Clamp-on design - no drilling needed
Required tilt is built into head assembly - no adjustment needed
Powder coated steel construction
System includes head assembly, adjustable shank, spring bars, lift chains, rotating lift brackets with handles, pin and clip, and all necessary hardware
Hitch ball sold separately - requires 1-1/4" diameter shank
Made in the USA
Blue Ox Instalation
Made in the USA
44,052 PostsLatest Activity: Oct 25, 2025
