Jebby14's avatar
Jebby14
weight distribution question
hey everyone. I have a weight distribution hitch im working on setting up. I was led to believe it was suitable for 600lbs of tongue weight but the bars have a larger number (if memory serves me its 1100). How can I tell what I actually have and what is safe to run. My trailer weights in around 5500 lbs with about 700 lbs tongue weight. What is the risk of running too strong weight distribution bars https://www.etrailer.com/Weight-Distribution/Pro-Series/49569.html
  • Jebby14 wrote:
    Fairly sure its 1200 marked on my bars so I think I have thiswould I be correct in assuming as long as I have 700 lbs of tongue weight im fine to use this hitch?
    If your trailer indeed does gross ~ 5500 lbs loaded & ready to camp then just 700 lbs of gross tongue weight (~ 12.7%) is on the light side. My previous KZ Spree's GVW averaged ~ 5500 lbs so I tried to run at least 750 lbs of gross tongue weight, 13.6%. At the time I was using an Equal-i-zer and because 600 lb spring bars would have been too light I had to run the next size up 1000 lb bars. Most round bar chain systems you linked to though offer 800 lb spring bars and that's what I would run in your case as 1200 lb bars are just too heavy for this size of trailer. My current Coachmen averages ~ 4800 lbs gross with an average gross tongue weight of ~ 625 lbs (13.0%) so the 800 lb trunnion bars I'm running are perfect.
  • Fairly sure its 1200 marked on my bars so I think I have thiswould I be correct in assuming as long as I have 700 lbs of tongue weight im fine to use this hitch?
