Whangler's avatar
Whangler
Explorer II
Oct 12, 2017
Weight Distribution Setup Question
I got a new Silverado 2500 LB, CC, 6.0 to tow my Arctic Fox 25r with. My Equal-izer hitch needed some adjustment as it was previously used with my Toyota Tundra on this trailer.
I followed the Equal-izer setup instructions and got every thing right except the trailer doesn't quite sit level. I turned the shank over to get maximum ball rise. With the truck unhitched, the top of the ball is exactly the same height as the coupler when the trailer is unhitched on level ground.
When I hitch it up and snap the spring bars on, everything is perfect.... except the front of the trailer is a bit too low. No amount of WD adjustment will bring the ball back up to unloaded height and level the trailer.
When the unhitched trailer is level, I get the following ground-up measurements along the horizontal trim:
Front: 28-1/4" Rear: 28-1/4"
When hitched up with wd, it measures:
Front: 27" Rear: 28-3/4".
Equal-izer instructions say to raise the ball if this happens. Fair enough. However, I'd have to get a taller shank to make the trailer sit level when hitched.
Visually, it's pretty difficult to discern the front being 1-3/4" lower than the rear of the trailer box. But, I'd need to put some wood blocks under the tongue jack and raise it up to get it level on those nights I spend in walmarts, rest areas, and truck stops.
Do you think it's problematic to tow with a 1-3/4" difference between front and rear of trailer box? Should I just bite the bullet and get a taller shank?
Thanks
