Whangler
Oct 12, 2017Explorer II
Terryallan wrote:
Don't think 1 3/4 inches will bother the TT. But it appears the rear of the truck is dropping 1 3/4 inches as well. What you need to know is how much does the front of the truck rise. If the front of the truck is not rising / unloading. You should be OK.
You need to get some truck front, and rear measurement numbers before, and after hooking up
Equal-izer instructions don't ask for rear truck measurement numbers, just front unhitched, hitched, and hitched with wd connected.
Hitched, without wd the front rises about 3/4" from unhitched. With WD it comes back down within 1/3" of uncoupled. That's right in there with what the instruction manual says.
GM HD trucks have a noticeable rake from rear to front. I suspect that may reflect longer suspension travel. I also suspect it may have progressive rear spring tension. Though the rear of the truck drops some, it doesn't appear to squat at all.
I haven't driven it yet but will soon. What would a slight trailer nose down do to handling assuming the truck sits nice and level?
