Baja_Man
Oct 20, 2023Explorer
Weight Distribution Shank....2.5" receiver end X 18" Long
RE:
'23 GMC 3500 4X4, Crew Cab standard bed
2.5" Receiver
I finally got around to setting up my travel trailer and Equalizer WD hitch.
Since my new truck has a 2.5" receiver, I purchased an Equalizer brand shank that is 2.5" on receiver end with a 3" drop and 7" rise. It's 12" long. My tailgate hits the electric jack when I attempt to lower tailgate. Tailgate must be taller than my previous 2003 Ford F350, as I was able to lower tailgate with a 12" long shank on that truck. It may also be that the Ford was a 4X2, or a combination of the two.
Can't seem to source a 2.5" shank that is 18" long, in any drop/rise format. I can find 18” length, but only for 2” receivers.
Anyone run into this issue? What did you do?
Were you able to source a 2.5" receiver end that is 18" long? If so, please share.
I considered using the 2.5” to 2” reducer that came with my truck and purchase the 2”x 18” long shank but have heard that the reducers can oblong or egg shape the truck's receiver from the slop and constant movement when towing heavy trailers.
Thoughts?
Thanks!
2.5" Receiver
Thoughts?
Thanks!
