Huntindog
Oct 21, 2023Explorer
Huntindog wrote:john, I am pretty sure that he is talking about the EQUALIZER brand components wich is not a standard WD hitch. Your Reese is a standard WD hitch.Baja Man wrote:I used the Equalizer 18" 2" bar on my 2011 Silverado dually with the 14K Equalizer hitch towing a 34' 11,500# TT for ten years and over 50,000 miles using the reducer. No issues at all. Now what will oblong the hitch hole is using a bent hitch pin, or any worn pin. When the bars are under tension, there is NO slop in the reciever.
RE:
'23 GMC 3500 4X4, Crew Cab standard bed
2.5" Receiver
I finally got around to setting up my travel trailer and Equalizer WD hitch.
Since my new truck has a 2.5" receiver, I purchased an Equalizer brand shank that is 2.5" on receiver end with a 3" drop and 7" rise. It's 12" long. My tailgate hits the electric jack when I attempt to lower tailgate. Tailgate must be taller than my previous 2003 Ford F350, as I was able to lower tailgate with a 12" long shank on that truck. It may also be that the Ford was a 4X2, or a combination of the two.
Can't seem to source a 2.5" shank that is 18" long, in any drop/rise format. I can find 18” length, but only for 2” receivers.
Anyone run into this issue? What did you do?
Were you able to source a 2.5" receiver end that is 18" long? If so, please share.
I considered using the 2.5” to 2” reducer that came with my truck and purchase the 2”x 18” long shank but have heard that the reducers can oblong or egg shape the truck's receiver from the slop and constant movement when towing heavy trailers.
Thoughts?
Thanks!
The 2" bar can be an advantage in the unlikely event you need to tow it with a different vehicle that has a 2" reciever. Rare, but it comes up here on the forum now and then. On a related note: That 18" Equalizer bar is made of a higher grade of steel and is rated to at least 14K
44,071 PostsLatest Activity: Aug 30, 2026
