nagel wrote:
You know I have been away from this forum for several years. What happened? It used to be a good place to get information....now it sounds like egos have risen to the top.
Wow....Sad. Maybe I read a sticker wrong and sometimes just looking for a little information and don't need the BS.....
Ignore the peanut gallery. There are still lots of helpful posters here.
I gather from your posts that the TT is 3500 dry, with a GVWR of 5400? Loaded for camping you'll probably be around 4500-5000 Tongue weight should be about 13%, so around 700 lb. I would use a WD hitch with that trailer and your half ton. The hitch adjusts to fit any TT tongue, so no worries there. The spring bars are rated for a range of various tongue weights, so get the ones that match or are a bit heavier than the trailer's tongue weight.
