Westsidebob's avatar
Westsidebob
Weight distribution system
Hello all, I'm new to the forum, it looks very helpful. I have a question about pulling with a F-250. We shopped today for a new rv, thinking about a 32ft bumper pull. The dealership is trying to sell us a weight distribution system and a sway bar. Do I need a weight distribution system? Do I need a sway bar? The trailer is 7765 pounds unloaded, and a dry hitch weight of 780lbs. I'm thinking I don't need the weight distribution, but maybe a sway bar? Thanks for any help!
  • 1000lbs on hitch I will say have a look at its rating a weight distributing hitch a good idear most wood say go with sway bar of som sort I don't use one.
    Frank.
  • ktmrfs's avatar
    ktmrfs
    Explorer III
    I'd say YES you will need a WD system, even with your F250. The dealer is being honest with you, not trying to sell you something you don't need.
    First, the "empty" tongue weight is likely to become around 1200+lbs once your loaded up. 2 batteries + propane will add almost 200lbs. Look at your reciever, you might even be over the Weight carrying capacity of the reciever once your loaded up.
    At 7800lbs empty, you will likely be push 9500-10,000 loaded up.
    And with a 32 ft trailer, yes you really should have a good a sway control system.
