ktmrfs
Jul 10, 2017Explorer III
RobWNY wrote:
I'm trying to figure something out. This past weekend, we went camping. A 400 mile round trip. I averaged 7.8 mpg going to the campground and 6.7 mpg coming home. The difference in mpg is easily explained by a head/tail wind, terrain etc. The trip was mostly East/West traveling. Today, I took my camper to the dealer for some repairs to the slide out and I knew it was going to be at the dealer for a while, so I pretty much emptied the trailer and front pass through storage before leaving. I'm guessing a 1000 pounds of stuff or more. I also didn't crank down on the weight distribution like I normally do because it doesn't raise the back of my 2500HD anyway no matter how hard I crank on the spring bars so I thought I would see how it towed this way. So to my astonishment, the trailer towed much better and I averaged 11.4 mpg. The trip to the dealer was all done driving North. So does 1000-1200 pounds cause that much difference in mpg or does weight distribution play a role in mpg or both?
short answer: Not really, it is on average a very minor effect when your towing a trailer with lots of wind drag and frontal area.
biggest impact is wind drag. On level ground and constant speed weight has almost no impact on fuel economy. you aren't doing any work moving the weight itself if the velocity doesn't change or altitude doesn't change. The work done is overcoming rolling resistance and wind resistance.
And when weight effects mileage, it is a linear effect.
Wind resistance is a square law effect. so even a 10 mph headwind can have a noticeable effect. same goes for bearing friction losses, engine rpm changes, they are all square law effects.
Now, during stop and go driving or going over mountains or in rolling terrain, then weight does have an effect, it's effect is related linearly to the change in speed, or the change in altitude or both.
now if your talking a car with low drag going through an EPA cycle or around town, then yes weight does have a noticeable effect. First wind drag is very low compared to a trailer. Second the work done is a lot of varying speeds. Then weight has a very noticeable effect.
My guess is that if you loaded that 1000 lbs back into the trailer and repeated the trip, it wouldn't make much difference. Even 1000 lbs when your talking 12K + lbs total is small compared to wind drag unless you never went over 30 or 40 mph.
As a real world example I have two trailers. the first is a cargo trailer, 7x14 with little frontal area and weight of about 5000lbs loaded. the second is a 35ft TT 10K lbs with about double the frontal area of the cargo trailer. Both dual axle. I travel quite a bit with one or the other. I've towed each of them over 25K miles, often on the same route. I keep track of the mileage towing each of them. the differnce between them over that mileage is less than 2 mpg. The big trailer averages in the mid 11 range with my diesel towing at between 60 and 65. The cargo trailer averages in the upper 12mpg range, same truck, same speeds. figure 1.5mpg difference at most. And a big chunk of the difference is the frontal area difference.
44,066 PostsLatest Activity: May 13, 2026
