Lynnmor
Apr 10, 2020Explorer II
LarryJM wrote:
The most commonly used friction bar has an adjustment which determines how much tension/compression it can produce. The magnitude of this is factory-set at 1100#. The center-center distance between the friction-bar ball and the main ball is 5.5". Therefore, at the factory setting, this friction bar can generate about 500 ft-lbs of torque. If you installed one of these bars on each side of the A-frame, the pair could generate about 1000 ft-lbs.
One difference between the friction-bar control and the DC and Equal-i-zer is that the friction force on the friction bar can easily be "turned off". Some people believe this is an advantage when towing in reduced-traction conditions.
Since the friction bar can and should be adjusted, where did you get the "factory-set at 1100#" figure?
