Huntindog
Apr 11, 2020Explorer
Lynnmor wrote:Just read the directions. The bar has a lever on one side and a bolt on the other. The lever is supposed to cranked down all the way every time. The bolt can be used to adjust it. The factory presets this bolt.Huntindog wrote:
Since the friction bar can and should be adjusted, where did you get the "factory-set at 1100#" figure?
I know that many here adjust them with the lever, but the intructions specifically state not to.
My instructions do not mention that 1100# figure, but it does say to adjust. Yes, I know how to use it, just wondering where the 1100# came from.Mine said it could be adjusted if needed.
The 1100# figure came from Ron Gratz. He did the calculations, as per Larrys post which copied him.
The adjustment has limits,as those little balls and bar can only do so much.
44,071 PostsLatest Activity: Aug 23, 2026
