aftermath
Apr 11, 2020Explorer III
BobbyHJ, you asked a pretty straight forward question and got all sorts of testimonials. People will always support their decisions about what they drive, what the pull and how they hook it up. Human nature I suppose. Many of these posts sound like advertisements. Mine is better because it resists sway, it reacts to sway, it pushes, it pulls and if you own a HA or PP they will say it totally prevents sway.
To answer your question, both will do the job. There are a nice selection of hitches out there today and as long as it is matched to your trailer and TV combo and is set up properly you should be good to go. Posts that mention things like the location of your tanks, whether or not you want to drill into your frame and stuff like that bring up good points. I would add ease of hooking and unhooking and making adjustments if things change should also be considered.
That said, I will now defend my choice of my Equalizer. I have been towing with this brand hitch for about 16 years now, first on a white box trailer and now on my Airstream. When I first started out, the hitches that used chains lifted into place were also problematic when it came to backing up. This has been fixed today so it no longer is an issue. This was the reason I went with the Equalizer. I can hitch and unhitch on uneven ground and come at my trailer from any angle. Placing the bars is easy and I have never had to even use the pry bars to put them in place. It tows nicely and even in the stiffest of winds, I have never had a problem with sway. I am a KISS kind of guy. When I have a choice between two good options I will look for the one that is the simplest to operate. HA and PP are great hitches, the best as their owners always claim, but they require special backing skills and techniques along with dealing with a very heavy hitch head. Won't be going there any time soon.
