jffkrn
Feb 02, 2014Explorer
Well I am sure you have already made your choice, decision etc. But I have to put in my two cents worth.. I have been towing trailers for about 15 years and have always used a weight distribution hitch with sway control Wouldn't be without it like the old guy stated. Also Barney is right on with his description of the bending potential. I used a sway WDH with Sway control bar that was removable. Only had to remove a few times due to tight areas where I had to jackknife trailer to turn around or turn into a spot. I now have an equalizer in which I like as it acts as both. I would add that lighter trailers often have some sway as large truck, crosswinds etc. are with you. Whatever you do, check out some videos on line, talk to folks and see some for yourself. Make sure a sales person doesn't sell you something you don't need or under what you need. You can install yourself, take your time or have it professionally done. either way, get one for your safety as well as others on the road. Good Luck & Be Safe ! ! !
44,068 PostsLatest Activity: Jun 21, 2026
