Seattle_Lion
Feb 03, 2014Explorer
aftermath wrote:
You might want to take a look at the Anderson hitch. It is relatively new on the market but it does have a pretty good following.
First, weight distribution. You might not need it. As long as your loaded set up doesn't drop the rear end of your truck to the point where the front wheels are too light, you should be good. Losing 160 pounds doesn't sound like a dangerous situation to me.
Sway control? All trailers are different. Some just tow easier and more stable than others. I tow and Airstream and it really rides nice back there. Do I need sway control? Probably not. I choose to have it since I do need the weight distributing hitch. I am glad that I have it because you just never know what kind of situation you might find yourself in.
I was coming down a very long and winding hill in California a few years ago. It wasn't all the steep but at the bottom there was an Airstream on its side in the median with the TV on the right side of the road. He was towing just on the ball and it looks like he lost it to swaying. There were marks on the road that looked like it was going side to side before he lost it. Speed, wind, hills, passing cars/trucks, bad road conditions, rain, snow are all issues that can create sway. Having a good anti sway hitch does not absolve you of all threat but it does help keep things under control better than the alternative.
Each TV maker publishes max receiver weight wit ou and with WD hitch. It's not a good idea to exceed them.
44,068 PostsLatest Activity: Jun 21, 2026
