blt2ski
Apr 02, 2014Moderator
Are we looking at this from a legal, or a rvnet wt police standpoint?
If a legal, you would have potentially upwards of 20K you can gross your truck at, not that I would recomend this. Going to axel limits is also not too much of an issue, ie over gvwr. Did that with my family of 6 on board two different trucks. Going over gcwr is nothing more than a warrenty issue, so over under, no big.
I was also over gcwr in my last truck by typically 4K lbs, but it did better performance wise than the previous truck with the correct gcwr.....In fact, I have had a few rigs with lower gcwr's than others, and did better pulling etc..... so gcwr in my boat any how, is nothing more than a warrenty/performance factor, where you do not know the performance specs, nor will you ever.
I personally will not tow more than 2x the grawr of the truck. For your rig, that would be 12-13K lbs, as long as I can stay under the axel wt ratings. Many on here thru the years have loaded there DA 2500's upwards of 16K of 5w, pulled great, but bottomed out the rear suspension in dips, going over speed bumps etc. I would suggest you stay at 5500 or less, other wise you will also bottom out at times.
Reality, there is only what you feel is best. Legally, an LEO can pull you over, and if they feel the need to, can sit you at the side of the road. Weight WILL NOT be one of them. This is from being pulled over, taking classes on what is and not legal for using pickups in commercial settings, which personal use has to, and gets the same rules and laws to follow.
Marty
Marty
