Mike and Terry Ann wrote:
They tried to rebalance and then took all the external weights off and used something call balancing beads.
DynaBeads are a band-aid for fixing issues that can't be corrected by match-mounting and proper balancing... There is
no way I'd use them in my brand new tires until I'd exhausted every other possible option. If a wheel/tire combo can't be made to balance with conventional weights (or even weight patches) then the manufacturer should warranty the tire and give you a free replacement.
As I stated previously; I suggest that you find a shop that knows how to mount truck tires.
Cheers
-Mark
