Steelhog wrote:
Sheriffdoug wrote:
Yeah, what stops the whole thing sliding off. Torklift Frame mount is the only wat to go!
The 3" square shank that locks into the gooseneck socket will prevent sliding. Very different but in theory it should work for most non off-road applications. If I recall the B&W gooseneck on my F250 is something like 7500lbs on the ball and 20 or 30K on total weight. Point being you can almost hang your truck on it so it should hold down a TC. I still trust my TorkLifts. Four connection points to the frame. But even then you are only looking at 300lbs X4 for pull down with traditional spring loaded tie downs.
But there's nothing to prevent the camper from sliding around on top of that frame, other than the centering guides. Also there's a lot of the bottom of the camper left unsupported. Interesting concept and I see some things I like, but a lot more that I don't.
