- profdant139Explorer IIAccording to Google, there are maybe 23 million people in Australia, versus around 40 million in just California, let alone the rest of the US. So how could it be that such a small population supports such a vibrant and creative caravan industry, far superior to the US?? I do not understand the economics of this situation. Someone will earn a PhD by studying this anomaly and solving the mystery. In the meantime, I feel deprived.
- shfd739ExplorerI want an Aussie trailer so bad...Fit, finish and function is so far ahead of the US makes..and it would look great behind my built 80 series Land Cruiser
- RoyBExplorer IILove the size and the layout is great... Make that in a 120VAC VERSION and sell some up here...
Roy Ken - RobertRyanExplorer
westend wrote:
Is that an induction cooktop? I wonder if the solar can keep up with the draw?
By the looks, it probably has a fuel cell.
Really nice ideas down under and the fit and finish looks great.
Seeing there is a lot of Custom items as well I guess you can get a fuel cell others offer them.Unique TopEnder design Hot-dipped galvanised Premium Strength double 4-inch beam chassis using A-Grade Blue-Scope steel, Step mesh on A-Frame, Rear drag protection bar & Recessed Spares with Additional Lockers
(Registered Design Pending)
Extended A-Frame, Stone Guard, 2 x Jerry can holders & Padded Sacrificial Stone Bra on upper front body also
6 Tonne Rated 360 McHitch Coupling
Upgraded Thickness Interlocked full aluminium wall frame using solid high-tensile steel punch pins with a welded 1-piece aluminium roof frame.
Choice of the New 'Cooloola' Italian made veneer, bonded to Solid Light Weight Ply, CNC Machined & Edge Banded Furniture or Hand crafted American or Tasmanian Oak Furniture (with the New Recessed TE'3, Oak furniture vans are limited to 19ft Body for weight)
High Quality Marine grade glass filled positive lock door catches.
Kedron's own 'Unique' Independent suspension with Military Style Leaf Springs & Shock absorbers.
12” commercial 'Marinised' brakes with flush plugs & agricultural bearings
16” steel / alloy rims, 265/75/R16 Goodyear quality steel belt radials including Twin Recessed Spares (Option of LC200 compatible 17' Wheels with Goodyear USA made 'Adventurers' available also)
Side protection Chassis Brush Bars (Innovated not copied!)
Propeller-plate scrub panels
Scratch resistant Powder-Coated Exterior Clad Finish in a choice of colours - Silver / Champagne / Jasper / White.
215litre 2-door 240/12volt compressor fridge
4-burner (3 Gas - 1 240v Hotplate) / Griller & Oven
Microwave - Secured with powder-coated steel brackets to furniture also
22” HD TEAC TV/DVD with wall brackets
Portable Satellite wiring
Air Command - IBIS 3 Roof Air conditioner
2 x 'Fan-Tastic' 12volt in/out Fan Hatches
JACK TV antenna
Upgraded European-made Tinted Double Glazed windows, with insect repellant brushes in rollers & silver frame finish
Shower / Toilet includes External Shower & Gas Hotwater System
Ensuite layouts include raised porceline sinks
3 separated 'KEDRON' Water tanks, uniquely made in QLD for bolting direct to chassis rails by robo-mould, baffled and Extra-Wall Strength - 2 x 100litre shower & 1 x 100litre drinking seperated with water filter & water tank gauges.
3 x 140w High Grade Japanese 'Kyocera' Solar Panels
3 x 120a/h maintenance free AGM batteries
40amp 3 stage float charger.
Vibration resistant L.E.D lights Internal & External with Upgraded Chrome Tail-light assemblies
Deluxe Quality Hide Leather Upholstery
Gal' Sheet lined 3/4 Through Boot Door-side & Generator Box Provision off-side on most model layouts.
STANDARD
INTERNAL
Full 12volt LED lighting system
USB Charge Outlets to suit Smart-phones at Bedside
Stainless Steel Range-hood
Radio / CD / USB / BlueTooth Player
Analogue Clock
12volt points
Down lights above lounge and dinette
Waterproof ply bench tops & bases of metal side roller drawers
Stainless steel deep basin sink with LED above
Mains pressure tap
Water filter from drinking tank
Inner-spring mattresses (Queen beds liftup on gas struts)
Luxury Quality Hide Leather Upholstery
Sectional Industrial Tile floor throughout
Smoke detector, fire extinguisher, earth leakage safety switch and more.
EXTERNAL
Sunburst Heavy Duty Roll out awning
High Density Styrene Roof & Wall Insulation
Pullout aluminium door step
H/Duty Drop down jack legs
Mud flaps behind Wheels, Under Van Front & in Front of Pull-out Door Step
Twin Rated Safety Chains
8-inch Metal centre jockey wheel
18” galvanised boot with light
Twin 9kg Gas Bottles
Triple lock security entrance door with entrance handle & light
External 240/12volt power outlets
Tap on A-Frame… - loulou57ExplorerThey look good. Even a washer dryer combination. Do you have one of these units?
- westendExplorerIs that an induction cooktop? I wonder if the solar can keep up with the draw?
44,029 PostsLatest Activity: Jan 28, 2025
