COBOZ
Feb 18, 2016Explorer
Just playing devils advocate here...but you are rolling the dice since you over the published weight rating of your truck, So you are choosing what number to ignore. I know very well that the limiting factors is the tires, but still doesn't change that number on the door jam. I will almost bet that every tire out there is really rated a lot higher than what is printed on the sidewall. The manufacturer is not going to make a tire that blows up when it is close to max. Look at Toyo/Nitto. There previous generation 285 tire was rated for 3750...the new generation is 3400. Nothing has drastically changed..its the lawyers/DOT that made them reduce. Not taking sides..just throwing out some facts.
